Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 12-21-2009, 12:11 PM   #1
phillyjizzle29
Key wont turn in ignition but makes the beeping noise
My key wont seem to turn over the car. It makes the beeping noise when its in the ignition but I cant turn it over or back. The wheel is locked but I can shift into all gears? Could a tumbler be off in the ignition? or is it the steering column? any help would be great!
phillyjizzle29 is offline   Reply With Quote
Old 12-22-2009, 08:33 AM   #2
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Key wont turn in ignition but makes the beeping noise
Is the steering wheel locked into position? You might need to turn the steering wheel a little bit to unlock the ignition.
2003 Dodge SRT-4
das2123 is offline   Reply With Quote
Old 12-25-2009, 10:07 AM   #3
Bear
If the key doesn ot turn then the ignition key lock cylinder is probably bad, a tumbler may be bad or the tumblers could be full of gunk (maybe some WD-40 in the key hole). On my '98, I bit the bullet and replaced the lock cylindereasy to do) and then had the new one re-keyed. This did solve my problem.
Bear is offline   Reply With Quote
