99 saturn Sl2 Front Brake Caliper
I need to replace the front rotors and brake pads on my 99 sl2 and I was curious as to the best way to release the pressure on the calipers so that I may fit the new brake pads in.
Re: 99 saturn Sl2 Front Brake Caliper
You push the pistons back in using a Brake tool or C-Clamp.
http://i4.ytimg.com/vi/CsUn9m4Y4_0/default.jpg
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man |
My rides: 2007 Chevy Equinox LT FWD 2018 Chrysler Pacifica Touring L "If women don't find you handsome, they should at least find you handy!" - Steve Smith (Red) |
Also, monitor the fluid level in the master cylinder-if you have added fluid with worn pads then most likely it will overflow when you push the piston back in to replace the pads. You might have to remove some of it to prevent a paint removing mess from happening.
