Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 12-21-2009, 10:34 AM   #1
svotta
1990 lumina stalls when hot
I have a 1990 lumina with 85k on it. yesterday I was driving and it stalled and wouldnt stay running for more than 3 seconds. I let it cool down and it ran fine until it got hot again. I know its the ignition moduale. Does anyone know how to replace one of them. There's 3 and how do you know which one is bad if I were to do it myself.
svotta is offline   Reply With Quote
Old 12-21-2009, 01:00 PM   #2
maxwedge
A990 racer
Re: 1990 lumina stalls when hot
There is only one module, 3 coils, the how to is at autozone.com, repair guides, register and put your car info in.
maxwedge is offline   Reply With Quote
Old 12-21-2009, 06:44 PM   #3
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
There's 3 coil packs, one ignition module mounted under them....the other likely culprit is the crank position sensor.
In the shop we used to do 'em both if the customer would go for it...they have a fairly similar service life, it seems.
If yours has the CPS on the front of the engine, make sure the wiring is not rubbing the crank pulley...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
