Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 12-21-2009, 09:27 AM
svotta svotta is offline
1997 g.m has trouble moving when cold
i ahve a 1997 grand marquis with about 190k. Recntly when i start it and let it idle down and oput it into drive and press the gas the rpms go down and it wont really move. once I get to 20 mph itll go fine. but when i press the gas it like studders then it goes. what could be wrong?
Old 12-21-2009, 11:28 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 1997 g.m has trouble moving when cold
When you hit the gas, the RPMs go down and not up? If they went up, I'd suspect a bad solenoid or worn out clutch for first gear. You'd be in second gear a little before 20MPH which is when you say you accelerate fine which is why I suspect something with the first gear in your transmission.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
