Old 12-21-2009, 12:57 AM
chrissbee77 chrissbee77 is offline
Question question about noise
i have a 01 grand prix gt 3.8 n/s.. it makes humming noise almost like a power steering pump but i want to be sure/. someone told me that i can take the belts off and then start it up and if the noise goes away then its a belt issue. my question is will the car start if i dont have the belts on and will it mess anything up?
Old 12-21-2009, 04:48 AM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Re: question about noise
Does your humming noise change pitch along with your speed? If it does and sounds like a single engine Cessna then It could be an hub bearing going bad.
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 12-21-2009, 08:43 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
You can run for a minute or so with the belts off without causing any damage.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-22-2009, 06:21 PM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
I've done it, but like Tim said, I wouldn't do it for long at all.
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 12-23-2009, 04:17 PM
so i took the belt off today and started the car i let it run for about a mnute or so at the most. The noise went away so my next question is what does that mean. the alternator test fine does this mean i have a bad belt tensioner or a bad water pump/ thanks everyone
Old 12-23-2009, 06:00 PM
tblake's Avatar
In God We Trust
With the belt off, you could turn each accessory and pulley by hand to feel for roughness. From there you should be able to figure out what the problem is.
