Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 12-20-2009, 09:34 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
02 Envoy front Axle problems.
A buddy has an 02 GMC Envoy and is having some issues with the 4WD. When you put it in AWD (and maybe all other 4x4 modes) the front axles just locks up (stops spinning) and if it wasn't for all the snow you would have probably been through the window.
Any Ideas?
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 12-21-2009, 07:14 AM
dorman68 dorman68 is offline
Re: 02 Envoy front Axle problems.
Check your right front axle housing, the bearings and parts in there are only lubricated by grease, the grease after awhile tends to dry up.
Old 12-21-2009, 07:24 AM
intimadatorsquizz intimadatorsquizz is offline
Those units do dry up, but also the shift fork breaks because of it and also the bearings go bad after the grease dries up. Let me know what you find out broke. The company I work for is looking into making these parts available to the aftermarket so I'd like to get your old parts from you. Send me a email to [email protected] for any other info.
Old 12-21-2009, 08:23 PM
Well I haven't gotten a chance to tear it apart, looks like tomorow I will be doing the job - found a used unit for $300.
I'm curious, if the grease in the axles dried up and locked the bearings up wouldn't this problem exist all the times, not just in 4WD.
Old 12-22-2009, 06:43 AM
the bearing may have finally blown apart the last time you put it in 4WD. I have a few bad ones here now and they're not pretty inside especially when the bearing blow apart. Good Luck and Let me know how you make out and if I can get the old parts from you.
Old 12-28-2009, 07:13 PM
UPDATE!
I finished replacing the differential early Christmas morning, the problem was deffinately the differential the Pinion Bearings were completely seized.
He said he had an oil leak a few months ago from the driverside axle seal and replaced it, I'm thinking they never refilled the differential, it was bone dry, although he said they it.
