Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-20-2009, 07:45 PM
posiman's Avatar
posiman posiman is offline
Cool 98 camry trunk lid
will a 2001 toyota camry trunk lid fit my 98 camry it looks the same but the tail-lights are different. i just want to know if it should line up. if so thats great!
Old 12-20-2009, 08:22 PM
JOET/CAMRY JOET/CAMRY is offline
Re: 98 camry trunk lid
They are both a 4th. generation Camry (1997-2001) so I would say yes.
JOET/CAMRY
Old 12-21-2009, 09:46 AM
Mike Gerber Mike Gerber is offline
AF -Advisor
What I do when I have a question like this is go to one of the Toyota dealer's online websites and check out the part numbers for both year's items. If the part numbers are the same, you have a positive answer to your question. If they are different, you also have your answer, just not the one you were probably hoping for.
Mike
Old 01-04-2010, 04:05 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
I would bet money the part numbers are different. However, they may be interchangeable. If you have access to a 2001, take alot of measurements with a tape measure and see if you can find any difference, particularly in the hinge mount dimensions and location relative to the front and sides. A small difference in the hinge would make it more difficult. In this type of situation, you may be able to, for example, replace the trunk and hinges as a set. Eventually, if you replace enough parts, the collection will fit. Hopefully, all you need is the lid.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Tags
camry , lid , trunk
