Old 12-20-2009, 06:42 PM
82Stang 82Stang is offline
dash lights intermittent
1997 Plymouth Grand Voyager SE @175K
Every so often, when going over a bump, the dash lights go out. Sometimes for a while, sometimes they come back on. I'm thinking there is a main plug or harness that may be loose. Any ideas on what/where to check?
Thanks.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 12-20-2009, 09:49 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: dash lights intermittent
By dash lights do you mean the instrument cluster, information center above the cluster and all the control knob back lighting or just one of these?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 12-21-2009, 03:13 PM
By dash, I meant the cluster. It just goes out. Other exterior lights, interior lights, etc are good. I assume a loose connection because of the bumps, but...
Rodney Dangerfield
Old 12-22-2009, 07:23 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Probably a problem with the cluster connector or the bad solder joint issue plaguing many 3rd generation vans. This shows you how to gain access to and if need be resolder the connector solder joints on the cluster circuit board: http://www.flickr.com/photos/landar/ Click "98t&c dash removal" on right column then slideshow at upper right.
Old 12-23-2009, 09:04 AM
I've had the dash out on it before and it is pretty easy and straightforward. The pics about the solder connection and cracked points on the back of the speedo, are very interesting and informative. Thanks for that. Now I know what to check.
Rodney Dangerfield
