Old 12-19-2009, 03:19 PM
carport1980 carport1980 is offline
replaced cps, still no start!! help!
i have a 99 jeep cherokee, i recently had the check engine light come on. I checked with my odb2 tester and found it was my crankshaft postion sensor. I've relplaced it but still have the same problems. Once maybe twice a week it will not start. If i go under the hood and unplug the sensor and plug it back in it usally starts. Now this trick is not working as often, ive retested the new sensor with a multimeter, and is fine........anybody have any ideas!! anythink will help.
Old 12-19-2009, 03:22 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: replaced cps, still no start!! help!
There have been several reports of getting a bad CPS right out of the box. Do you have any other codes?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 12-19-2009, 03:26 PM
yes, i also had a camshaft position code. I bought a used distributor, and put it on to solve the problem, but the Codes for both are still showing up.
Old 12-19-2009, 03:29 PM
Well an electronics guy should show up soon to have a look; but you may want to check the wiring harness for any worn insulation. I've seen a few posts where the insulation near the computer was worn and caused odd issues.
Were you getting the crank sensor code before?
Old 12-19-2009, 03:32 PM
Thanks for the help, ill check it out.
Yeah, both codes came on at the same time.
Old 12-19-2009, 03:56 PM
Saudade's Avatar
Saudade Saudade is offline
Problems with the CPS connector are quite common. Best bet is to cut it off and solder slices directly onto both sides of the harness. You can "google" around to find lot's of posts on this subject.
Also make sure the harness didn't hit the exhaust manifold and burn through.
Dad's taxi:
'88 XJ - 190K and going strong.
K&N, Ford Injectors, No other mods
Old 12-19-2009, 04:06 PM
jd-autotech jd-autotech is offline
i would check the crank signal with a scanner and see if your live data screen loooses info, display. then make sure no connectors are backing out of the harness when you plug it in.
Old 12-19-2009, 08:03 PM
i checked for bad lines, and made sure all my grounds were solid. The connecter seems to seat really well but Im still going to soldering the lines. thanks for all the info, ill def get back to all.
Old 12-20-2009, 04:56 PM
DIVERHERB DIVERHERB is offline
You might want to check around the back of the head. There has been some issues of the harness shorting on the very back left side of the head. I would check that before I hard wired the sensor.
