Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-19-2009, 10:29 AM
1997SATURNSL2DOHC 1997SATURNSL2DOHC is offline
service light (wrench icon)
HAD DTC0341
FOUND CONNECTOR UNDER COILS UNLATCHED
CLEARED CODE WITH SCAN TOOL
NO DTCs READ
SERVICE LIGHT STILL ON
IF THAT WAS THE PROBLEM, WILL IT CLEAR AFTER A CERTAIN NUMBER OF MILES/RUN CYCLES?
Old 12-19-2009, 09:29 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: service light (wrench icon)
Originally Posted by 1997SATURNSL2DOHC View Post
HAD DTC0341
NO DTCs READ
If your troublecode was indeed a PO341, that is indicated by the "Service Engine Soon" light and not the wrench light that simply says "Service". The wrench light doesn't come on with issues associated with the engine/powertrain. It requires a more advanced scanner to check the code(s) that are causing the wrench light to come on. A run of the mill inexpensive OBD-II reader cannot scan these codes.
As far as the P0341 code goes, check/replace the spark plugs, wires, and the grounds on the coils that go to the mounting bolts of the coils/ignition module. Those grounds sometimes become corroded and cause that code. Only use standard copper core spark plugs (NO platinums).
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 12-20-2009, 11:50 AM
RC1488 RC1488 is offline
When the key is initially put in the RUN position, check to make sure all the icons light up. If the wrench bulb is out, the SES light will turn on.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 12-20-2009, 02:30 PM
Ruley73's Avatar
Also, IIRC if the battery light is burnt out and doesn't come on during the initial self test, the alternator won't charge and the wrench light will come on too.
My rides:
- Steve Smith (Red)
Old 12-22-2009, 11:58 AM
Could it be something as simple as a bulb burnt out?
Old 12-29-2009, 10:38 AM
yupperz
Old 01-21-2010, 01:40 PM
Hi everyone,
I believe I have fixed the wrench icon problem, (without having to pay someone $70 to read the code.....which did not display using an inexpensive OBDII reader.) See if you can figure out what the problem was. After visiting the emission test station and getting rejected for "readiness monitors not set", (and having driven 400 miles) the kid working there said something that got me thinking. I fixed the problem. I got it (the service icon) to turn off. I will post the answer next week after I pass my emission test.
Old 02-20-2010, 04:44 PM
passed emission test finally
1)readiness monitors were not set because of..............a bad thermostat!
the engine never got up to operating temp (only got up to about 160F) I found this on my own with a thermometer. That took care of the readiness issue and the SERVICE LIGHT (wrench icon)
2)then got a DTC 0420.........bad CAT (converter)
I suppose the better scanner would have flagged the bad thermostat(???)
thanks everyone...I was able to save a few bucks
