Go Back   Automotive Forums Car Chat > Buick > Regal
Old 12-18-2009, 11:58 PM
ErickF ErickF is offline
93 Regal: Engine won't shut off, ignition switch turns freely
I have a 93 Regal Custom. The engine was running but when I turned the ignition switch to the off position and removed the key the engine was still running. Was only able to shut off vehicle by disconnecting the battery. I thought it may be the ignition lock but have also read it could be a arm/rack mechanism that could be broken. When turning the ignition switch it no longer feels like it's catching like it had done before when going through the accessory/off/on positions. Any help on this is greatly appreciated. Thanks.
Old 12-19-2009, 12:12 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 93 Regal: Engine won't shut off, ignition switch turns freely
You are correct. Inside the column, when the lock cylinder rotates, it is actually moving this sliding switch up and down, like a tiny rack-and-pinion gear. In your case, it sounds like something mechanical has broken or is worn out.
Given the age of the car, it may be cheapest and easiest to locate another steering column from a wrecking yard. Any decent wrecking yard can advise you on what models and years of GM cars are interchangable with yours.
Old 12-19-2009, 09:23 AM
Thanks for the reply. Do they offer a repair kit for the broken arm or gear? I haven't completely torn into the column just yet but I am pretty positive that this is what broke. Thanks.
Old 12-19-2009, 09:45 AM
MagicRat's Avatar
I have never heard of one. Usually this problem does not occur often enough to require a kit.
If you are lucky, you may be able to fix it by replacing the lock cylinder only, but of course, it depends on where the damage is.
Replacement cylinders are available through the dealer or a locksmith.
Old 12-19-2009, 12:42 PM
inafogg inafogg is offline
yes you can buy the parts.but until you have a look you dont no what is need.could be accuator rod has come undone or rack is worn.they sell kit for when cars get stolen & they bust out the colunm fairly common.Good Luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 12-19-2009, 04:21 PM
MagicRat's Avatar
Good point. Theft damage is by far the leading cause of GM column repair requirements.
Old 12-19-2009, 06:56 PM
Thanks for all the help. I did get it taken apart earlier today and the rack part is broken. I might just check out the cost of a good column from a salvage yard as the blinker switch needs replaced and the horn doesn't work. Thanks again for the help.
Old 12-20-2009, 06:32 PM
do what you want but........you no the history of your colunm
the cost for parts are probaly a lot cheaper than a used column
the time spent on repairs is aleast double
Live For Today
Yesterday is gone,
