Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-18-2009, 08:12 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
I GOT the 350!!
Its finally in my possession after all that talk! It needs a bit of cleanup but it runs and has about 7-8000 miles on it. I think im gunna paint the block that typical chevy orange. So paint, new valve covers, and a light carb cleanup is all it needs. It was $750. AND it even came with a beefy alternator which i have been wanting. Only bad part is this opened up a whole new can of worms of stuff i should really do when the engine is out like replace fuel lines and cleanup the engine compartment. But hey, itll be worth it in the end if its all done right the first time.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 12-19-2009, 08:38 AM
j cAT j cAT is offline
Re: I GOT the 350!!
before installing replace oil pan gasket...
Old 12-19-2009, 04:56 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: I GOT the 350!!
And while you are at it, take a quick look at the bearings. Look for abnormal wear patterns, excessive clearances and other damage. Consider using Plastic-gauge to measure clearances and retorque the bolts to spec.
I have encountered several freshly-rebuilt engines that were not properly cleaned prepped prior to final assembly, causing contaminents inbedded in the bearings, scored journals, spun bearings, stretched/weak bolts, improper bolt torque etc.
Old 12-20-2009, 01:37 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: I GOT the 350!!
I think this was a Goodwrench 350 crate motor, am I correct?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-20-2009, 01:39 PM
bhw33191's Avatar
Re: I GOT the 350!!
Uhh. I'm not not sure really. The guy i got it from said he bought it from the Chevy dealer near him.
