Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 12-18-2009, 06:15 AM
ksracing71 ksracing71 is offline
Gas smell in air vents
This morning while driving with the heat on, I had a really bad gas smell come thru the air vents. This only happened while sitting at a stoplight. After pulling in a parking lot and popping the hood, I didn't smell gas in the engine compartment. Anyone heve/had this poblem before? It's a 2001 by the way. Thanks for the advice.
Old 12-18-2009, 01:37 PM
65comet's Avatar
65comet 65comet is offline
Re: Gas smell in air vents
Unless it happens again, I would guess it is unburned gas from another vehicle coming out of their exhaust or another vehicle had a leaky gas tank and was previously stopped right where you stopped. If you had a leak, you would smell it later.
Old 01-02-2010, 07:13 PM
Unhappy Re: Gas smell in air vents
it's definitely my truck. But I don't see or smell leaks while under the hood looking for it.
Old 01-08-2010, 06:40 PM
Davescort97 Davescort97 is offline
Escort guy
Check the fuel pressure regulator at the fuel rail. Also, check the connections to the fuel filter which is on the firewall just even with the driver facing head on.
Old 01-08-2010, 06:45 PM
danielsatur danielsatur is offline
Was your truck at normal engine temp, or was it still cold?
Don't forget about the EVAP system!
