PEASE HELP!! wife stained my dashboard
my wife sprayed my dashboard with some anti bacterial-germicide stuff, and it stained my dashboard it looks like i have hard water stains (runs) on my black dashboard my car only has 72000 miles and the dashboard was perfect before this what can i use? i tried just a hot washcloth and some glass cleaner thanks in advance!
Re: PEASE HELP!! wife stained my dashboard
Try some armorall dash cleaner, better than window cleaner. You can ever try spraying a little wd-40 on a rag but try the armorall first.
Remember K.I.S.S ( keep it simple stupid )
Some of those anti-bacterial aprays have bleach or other similar active biocides which can react with the pigments (usually also organic) in the plastic. No amount of Armor-All will replace that.
It will be a PITA, but your best bet is to repaint the dash with a paint specifically made for plastic. Look in the auto parts store in the paint section and follow the directions. The important thing is to make sure the surface is clean and free of oils (such as Armor-All) and mask off EVERYTHING you don't want paint on...the spray will go EVERYWHERE. Don't forget the ends that butt up against the door. If you can remove the dash from the car that's best (Yes, an even bigger PITA!) because you can then do it in a controlled environment such as a garage. Which reminds me of another important point...temperature. If you don't have space heaters, I'd suggest waiting until spring to try this as paint won't cure well in cold temps...READ the directions. Good luck and let us know how it goes!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
Don't take any shortcuts you should use proper dash paint otherwise you will have to live with the horrible results (and so will the next owner). Good luck
car buying guide |
