Old 12-16-2009, 11:10 AM
castilla's Avatar
castilla castilla is offline
Can't pull code's
Its seems that this F150 does not wanna give up any info.
the data link connector is getting power but it fails to connect to the computer. All fuse's are good and relays too but it doesn't connect. any ideas? Drive's fine no CEL on. I did notice that the Radio would reset it self when i turn on the head lights but that was resolved by replacing the battery it had like 234CCA so it would drag to turn on.
05 F150 crewcab TxEdition 4.6L
Old 12-16-2009, 10:00 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Re: Can't pull code's
PCM might be no bueno. Thats about the only thing I've ever seen no let a scanner pull codes other than a blown fuse.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 12-17-2009, 12:26 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
I'm not certain what protocol the 05 Fords use, but it could be that the code reader does not support that protocol. I believe that the 05s still used the SAE J1850 PWM protocol but don't quote me.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 12-17-2009, 01:37 PM
dfordski's Avatar
dfordski dfordski is offline
ECU"s are pretty resilient. there's a lot of stuff that can go wrong that would imply a bad ECU. Here's a Link that lists those things:Ford Fuel Injection » No Codes?
"Saving the World......One Ford Truck at a Time!"
