Old 12-15-2009, 05:08 PM
super_man_736 super_man_736 is offline
Cavalier rims
I have a 1996 cavalier 2dr would a set of 205 75 r15 tires fit under the car and the wheel wells without rubbing
Old 12-15-2009, 07:17 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Cavalier rims
No, 195/75/14s are just about the biggest you should go, they come 1/2" from rubbing when the wheels are turned. Probably come really close to rubbing on bumps. 205/75/15 have about a 1" bigger diameter than 195/75/14.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
