Old 12-15-2009, 01:56 PM
cramer_77 cramer_77 is offline
1995 Buick LeSabre oil leak
3.8L non-supercharged engine, 86,000 miles. Oil leak seems to be coming from around oil filter housing where it bolts to block. So originally we replaced the gasket thinking it had blown out over time. Didn't fix it. So we replaced it with gaskets from the dealer, still didn't fix it. We were told that the housing itself is a discontinued item and that it cannot be bought. We are running out of ideas, any help would be greatly appreciated.
01 Silverado 2500HD, HID lows and highs, cold air kit, leveling kit, brush guard, dual flowmaster outlaw mufflers, 5% windows.
Old 12-15-2009, 03:24 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 1995 Buick LeSabre oil leak
Usually the front cover gasket will leak, but appear to be the oil filter housing. They are so close together, it's hard to tell where it is leaking.
Old 12-17-2009, 08:48 PM
Angry Re: 1995 Buick LeSabre oil leak
Yeah after looking at it really hard, then getting my boss to look at it, we finally did notice it was the front cover, made me so mad when i seen that to, cause i had to stay late the night before and didn't get paid for it.
Old 06-20-2013, 02:46 AM
jman_69 jman_69 is offline
What exactly is a front cover gasket b/c I'm having this same issue and I have replace the gasket but I still have the oil leak
Old 06-20-2013, 06:38 AM
Tech II Tech II is offline
More often than not, it's the oil pressure switch/sender, located above the filter that is the culprit.....remove the harness and if there is oil on the contacts of the harness, the switch/sender is leaking.....sometimes it leaks out of there and is flung by the serp belt, making it hard to notice the source....
