Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 12-14-2009, 07:01 PM
UKwildcatfan09 UKwildcatfan09 is offline
98 Durango - wont start - need help
Have a 98 Durango that wont start. Will turnover but wont fire at all. Was running fine previously, also none of the instrument panel gauges are working at all now. Security light comes and stays on too. Seems like all this is somehow connected.
Initially had blown rear brake cylinder, was moving inside to replace, when all of a sudden it wouldn't start and this whole new issue. Dont think that has anything to do with this.
Replaced the battery, but at a loss here - any ideas??
Old 12-15-2009, 11:11 PM
hundahunta hundahunta is offline
Re: 98 Durango - wont start - need help
leave the key on for about a minute or so, check the odometer does it display "NO BUS"
Old 12-17-2009, 04:52 PM
Turning on the ingition does not give me a "NO BUS" error, the mileage just blinks.
I have also noticed the SECURITY light now stays on all the time - never noticed this before. Could somehow it activated something preventing the car from starting?? It has never had an alarm/security system on it since we've had it.
Old 12-17-2009, 10:22 PM
possibly sounds like a bus problem failure...I would try and disconnect your cam, crank, tps, map, ac pressure, power steering switch and re-check your gauges. I could be a variety of problems, are you able to check does or use a scanner....
