Old 12-14-2009, 06:03 PM
dkc_2001 dkc_2001 is offline
Unhappy Serpentine belt squeek, car cuts off
I have a problem with my '02 windstar. The van was squeeking while warming up, then will intermittantly squeek, especially decelerating, then the engine cuts off. I had the serpentine belt replaced and could still hear the squeek at the shop, they used a listening device and told me the offender was the water pump. As I was driving to another shop to get the pump looked at, I decelerated and the squeek happened again, and again the car cut off. Is the water pump pully locking up causing this? Has anyone experienced this?
UPDATE- the mechanic told me it wasn't the water pump, but a "cam sink"??? He said it was fairly common on Fords. Anyone have any info on this? I've never heard this term before.
Old 12-17-2009, 05:30 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: Serpentine belt squeek, car cuts off
You should ask him instead.
I think he meant the cam shaft makes noise becausee of the friction. You may need to replace the shaft to get rid of the sound.
Your mechanic is crap. He should know from the 1st time the cause of the sound. When belt was removed, if sound persists, then it's definitively in the engine, not accessory drive.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 12-17-2009, 05:38 PM
12Ounce 12Ounce is offline
Search for "camshaft sensor" and "camshaft synchronizer".
You may get by with a few drops of fresh oil on the synchronizer. The camshaft position sensor has to be removed first. Easier written than done.
Old 12-17-2009, 11:45 PM
The first mechanic was Merchan'ts, just had the belt replaced. I knew I needed to take it to someone a little more knowlegeable for the correct diagnosis. Had the cam shaft replaced as you said. No more sound, $250 later.
Thanks!
