Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-14-2009, 05:08 PM
PawnofChaos PawnofChaos is offline
Angry 95 SL2 won't start
Started rough last Thursday and hasn't since. She turns over and sometimes fires. Sounds like she wants to start but then sputters out. I've changed the plugs and verified that all four are firing. Seems to be getting plenty of fuel. I have noticed a drop in MPG over the last month or two. Is it running rich and why? 195,000 miles. Newer raidiator, starter, battery, gaskets down to the block. Does burn oil. (like most)
Old 12-14-2009, 05:27 PM
Re: 95 SL2 won't start
Upon further reading, it sounds like a bad ECTS. What do you think? Where is it at if bad?
Old 12-15-2009, 09:02 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
If it's never been replaced, it's very likely the ECTS. Look on the driver's side of the cylinder head and you should see two sensors. You will probably need to remove the air intake hose for access to them. The top one is the one wire temp sending unit that is used by only the temp gauge. The bottom one is the ECTS with two wires. When the ECTS it can cause a wide variety of symptoms problems. It requires a deep-well 13mm socket to remove. Use a dab of RTV silicone on the threads if there isn't any thread sealant on the new sensor.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 12-16-2009, 06:03 PM
Thanks for the quick response. I had already gone ahead and changed the ECTS (very fine crack) and got it running. Runs well but seems to idle awfully low, has stalled once but started right away. I also have an intermitent SES light as well. Any suggestions? I plan on having the code checked tomorrow at the local auto parts.
Old 12-16-2009, 06:39 PM
Ruley73's Avatar
What's awefully low? A DOHC M/T should idle at 850 RPM in neutral, at a stop (w/o the applying the brakes), without the A/C on, after the engine is completely warmed up (at least ~3/8 on the temp gauge). A DOHC A/T should idle at 950 RPM under the same circumstances.
Regardless, find the SES light code and go from there.
My rides:
- Steve Smith (Red)
Old 12-16-2009, 10:44 PM
RC1488 RC1488 is offline
Clean your throttle body.
Drive the car around. See if your idle changes
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 12-22-2009, 01:28 PM
All is well again. Drove it around for a day or so and the rough idle is gone. Does idle low (400-500) when warmed up and in nuetral (5 speed). Has not stalled since the rough idle went away. Cannot get the occasional SES light read as I'm being told by several auto part stores that they can only read codes on 96 and newer vehicles. Connector changed in 96 they say. Well anyway, thanks again everyone for your time and help.
Old 12-29-2009, 10:40 AM
Thats to low and giving you missfires. Clean your throttle body including the IAC. I've posted videos here for it before, so use the search button. If you can't find them Ill repost them.
You can also check the codes with a paper clip. Again I've posted instructions for that
