Old 12-14-2009, 02:05 PM
lildevil2956 lildevil2956 is offline
need help...ASAP
i have a 2000 silverado 1500 2wd. i need to remove the heater core. how do i do that? also how to i remove the handle on the air bag of the passenger side? thanks i really need your help.
Old 12-14-2009, 02:24 PM
jd-autotech jd-autotech is offline
Re: need help...ASAP
may i ask why? are you having a heat problem?
Old 12-14-2009, 02:26 PM
on many models the take dexcool (pink gm coolant) the coolant gums up the heater core and can often be resolved by flush/back flushed the core from the heater hoses
Old 12-14-2009, 03:17 PM
i already flushed it. so i went buy one and i took off what i thought was all the bolts for it but it wont come out. so im asking how to you take it out. and also how to you take off handle off the airbag. i took off the clips but the handle wont come off.
Old 12-14-2009, 04:25 PM
j cAT j cAT is offline
the only time you replace this is IF it is leaking .......................
if it is not leaking and you have NO HEAT this may mean if it is noT plugged ,,,,,that the temperture control motor/damper door is stuck/defective ...this is a common problem when the cabin air duct filter is not installed...
If you are not busy and want a nice puzzle to do replacing the heater core means removal of the entire dash among other things......
NOT AN EASY REPAIR...NOT FOR THE NOVICE...
HAVE FUN ...
