I have a 1995 Mercury Villager w/195,000 miles. I discovered brake fluid leaking from the Pressure Metering Valve. How can I fix it or where do I purchase a new/used one.
Help… |
Re: Pressure Metering Valve
Could you explain leak better or post a pic of the problem area?? Salvage yard may be the best place for a actuater. Here is a link that shows the competents of the system, maybe that will help with showing which part you are looking for: http://f1.grp.yahoofs.com/v1/UKcmS_d...ed%20Views.pdf Here is another link for parts: http://www.tascafordparts.com/index.do Tascafordparts Last edited by tempfixit; 12-14-2009 at 05:15 PM. |
Thanks Larry,
This part located above the rear axle is what Ford calls the brake load sensor proportioning valve. Should you need to order this pat dirrectly (F6XZ2B547AB) Brakes Hydraulic system, Pressure metering valve Villager $177.00. http://www.TascaParts.com Darwin |
