Go Back   Automotive Forums Car Chat > Honda > Classifieds
Classifieds This is the place to buy and sell your Honda parts.
Old 12-13-2009, 05:44 PM
Rhinoed_F150_ Rhinoed_F150_ is offline
Lots of 92-95 Honda Civic parts for sale...can a mod please send me a pm please.
Keep in mind I have alot more parts than you see pictured.
And please be polite and bump the thread for me.
If you bump the thread and buy something from me I will cover the paypal fees.
I am paypal verified with over 5000 transactions.
May trade for something of value...What ya got?
call or text 662-305-5000
ICEMAN
Between 1 and 1.5 carats of diamonds. Yes they are real. Sold for $2200.00 on sale....MAKE AN OFFER!!
I have a d15 vtec from a 92 cx hatch back. Rattle/knock in the lower end.
Good head, vtec valve cover. Was still running when pulled.
I am parting this car out. 92 civic cx. 5 speed car.
May sell whole for the right price.
I got a low milage 1998 H22 VTEC COMPLETE TOP END for sale.
Head with valves. I have the cams and caps also.
Looks rusty in pics but it is not. Will take more photos if you need them.
H22PARTS REMOVED FROM A 98 PRELUDE
H22 HEAD
I have the cams and gears also.
PLASTIC INJECTOR WIRING HARNESS COVER
H22 WATER OUTLET FOR THE HEAD
H22 ENGINE HARNESS
H22 THROTTLE BODY
H22 HEADER
Perfect Cond.
Also have :
cams and gears
In the meantime feel free to contact me with your civic needs.
You can also text or call me at 662-305-5000 up until 3 am.
Thank you.
Several ignition switches...Wiring and lock cyls with O.E.M Honda keys.
95 Passenger Air Bag (BLACK).
96 Integra Tilt Column.
96 Integra Ignition switch with OEM key.
96 Integra black steering wheel.
96 Integra SRS Clockspring.
96 Integra cruise control buttons.
96-00 Tilt Steering Column.
92-93 Gray glove box.
92-95 Coupe and Hatch Door glass
92-95 Shift Linkage
92-95 Alternator
92-95 Hood Latch
92-95 D Series VSS
92-95 Hood Release Cable
92-95 Hood Release Handle
92-95 Hatch Rear interior wiring harness.
92-95 Minty Headlights L and R.
92-95 Hatch complete lock and key set. Doors, hatch, ignition.
92-95 EG Hatch Gray Carpet.
Plus much much more.
The D16Z6 had 110k miles on it.
D16Z6 HEAD.
D16Z6 INTAKE MANIFOLD.
D16Z6 UPPER TIMING COVER PIECE.
Shoulder bolt included.
92-95 CIVIC PEDALS
D16Z6 FUEL RAIL.
D16Z6 FUEL PRESSURE REGULATOR.
D SERIES IACV With only 10k miles on it.
[b][b]92-95 COOLING FAN HARNESS
D16Z6 VTEC SWITCH with 110K MILES.
Pictures soon
B16A2 INNER TIMING COVER PIECE
SONY ERICKSON WALKMAN for AT&T
Works perfect and comes with memory cars and 2 chargers.
P05 ECU FOR 5 SPEED
VIRGIN P28 ECU FOR 5 SPEED
$125.00 Shipped.
92-95 CIVIC UPPER WINDSHEILD MOLDING
92-95 CIVIC UPPER WINDSHEILD MOLDING CLIPS
92-95 CIVIC WINDSHEILD MOLDINGS
OWNERS MANUAL FOR 92 CIVIC
92-95 CIVIC D SERIES THROTTLE CABLE
92-95 HEAT AND A/C CONTROLS
92-95 OUTER DOOR HANDLES
Have fronts and rears from 4 door
01-02 CIVIC TILT STEERING COLUMN
92-95 CIVIC TILT STEERING COLUMN
92-95 CIVIC STANDARD STEERING COLUMN
STEERING COLUMN JOINT
01-02 CIVIC IGNITION SWITCH w/ KEY and WIRELESS REMOTE
GRAY CENTER CONSOLE
Minty Clean
92-95 GRAY DASH
Removed from a 92 no pass air bag.
UNDER DASH TRIM
Grey
UNDER DASH TRIM
Black
BLACK INNER HANDLE TRIM.
92-00 WIPER SWITCH
FUSE ACCESS DOOR
Black
FACTORY AIR FILTER BOX
Filter Included
POWER MIRROR
Right Side - 2 door and Hatch
92-95 CIVIC HOOD HINGES
MAIN RELAY
D SERIES STARTER
Automatic Transmission
Also have one for a 5 speed manual
92-95 INSTRUMENT CLUSTER
STOCK D SERIES INJECTORS
$8.00 each shipped
LEFT FOG LIGHT EG. Lense busted. Bracket good light is prob good.
UNDERHOOD FUSE ASSORTMENT
AIR BAG SRS REEL CLOCK SPRING
Removed from a 2001 civic
WIPER SWITCH FOR 96-00 (EK) HATCH w REAR WIPER
I also have one for the 2 and 4 door.
D SERIES POWER STEERING BRACKET
92-95 CIVIC SUNROOF RELAYS
92-95 DOME LIGHT
Removed from a 92 CX HATCH
D SERIES VTEC
AUTO TRANSMISSION FLYWHEEL BOLT
HOOD/TRUNK RUBBER ADJUSTERS-STOPPERS
94-95 EG AIRBAG HARNESS
92-95 EG TAN CENTER DASH VENT
92-95 GRAY EG CENTER DASH VENT
92-95 GRAY EG HANDLE TRIM
88-00 WINDOW CRANK
Have one tan one and one gray one in stock
92-95 GAS DOOR FROM HATCH
92-95 REAR HATCH STRUTS
92-95 GAS AND HATCH RELEASE TRIM
Gray in color
92-95 2 DOOR OR HATCH GRAY SPEAKER COVERS
O.E.M. 5 SPEED SHIFT KNOB
BLACK 01 CIVIC STEERING WHEEL
Minty clean
92-95 STEERING WHEEL BROWN
92-95 AIRBAG BROWN
Also have a gray one.
96-00 IGNITION HARNESS
96-00 IGNITION SWITCH WITH KEY
92-95 UNDERHOOD FUSE BOX COVER
CLUTCH RESEVOIR and BRACKET
GREY EBRAKE BOOT
SUNROOF RELAYS
92-95 CIVIC WIPER TRANSMISSION
92-95 CIVIC CLUSTER BEZEL
POWDER COATED TOW HOOKS
96-00 INNER DOOR HANDLES
From 2000 civic Si Minty clean
REAR PLATE TRIM PANEL
LEFT SIDE HATCH TAIL WITH BULBS AND HARNESS
Have a full set from 92-95 4 door sedan and 92-95 hatch
[b]You can pm, call or text me @ 662-305-5000 for more details.
