Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 12-13-2009, 03:12 PM
94hd 94hd is offline
Send a message via Yahoo to 94hd
92 4runner wont lock into 4wd
I have a 92 4runner with v6 5speed maneul tranny it has the A.D.D hubs ,when I put it in 4wd its not going into 4wd the 4wd indecator in dash is not coming on ,that could be a bad bulb cause it doesn't come on when you turn key on.The transfer case is working all right .Its something in the front end thats not engageing .I noticed on the front diff. there is some kind of solenoid there with vacuum hoses and a electrical connection .Does this have anything to do with it not locking into 4wd?
Old 12-13-2009, 06:57 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: 92 4runner wont lock into 4wd
There are several switches, relays, and vacuum solenoids in the ADD system.
Lock and Unlock vac solenoids failures are common.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 02-10-2010, 12:57 AM
OzzyO's Avatar
OzzyO OzzyO is offline
Send a message via MSN to OzzyO Send a message via Yahoo to OzzyO
Check your actuator, not sure of the spelling, I had the same problem and replacing that fixed it.
