06 LE new to me...problems???
Hello just got and 06 LE with 45,000 miles.. what do I need to be looking out for??? Problems? what should I inspect for wear? Thanks
Re: 06 LE new to me...problems???
Belts, hoses, tires... Just the normal wear and tear. My mom bought a 04 with over 100,000 mi three years ago and everything is still great. Enjoy.
91 Toyota Pickup - Lowered, Racing Suspension, 96 Toyota Supra 2JZ-GTE Engine w/ 6 speed man. trans. - Crashed racing SCCA - RIP 86 Toyota Pickup - 4x4 - Chevy 305 Engine - Rest stock toyota Current Project - 90 Toyota Bedless Pick-up - My new mini - Currently Lowering and finding a new bed. The flat bed went to my dad's truck. Merry Christmas Dad!! Worked: Doxon Toyota - 4 years Bowen Scarff Ford and Scarff Ford- .5 years |
Thanks...seems like the brakes are very touchy. What I mean is that very little presure is need to stop quick making it had to stop smoothly.
My 06 is the same. The van is hard on front tires. Rotate every 6 months, you should be fine. Good luck with the van.
Best thing you can do with any vehicle is to stay ON TOP of maintenance.
This is the #1 thing that gets folks into trouble....folks tend to drive a vehicle, only filling the gasoline tank.....most having the ol changed.....and nothing else until a problem comes up.....and that does not get you the most years of service out of your vehicle.. I would change the oil and filter every 5K miles using a quality oil (I am partial to synthetic). Change the transmission fluid as called for, and change the power steering fluid every 4 years or sooner (uses Automatic Transmission fluid, as called for in your owner's manual). You have purchased a vehicle that should give you years of GREAT service. The advice about rotating tires is spot on......I have owned a number of front wheel drive vehicles....and while the front tires will wear faster......the rear ones will "cup"....get flat spots on them if you don't rotate them regularly. This has been the case on EVERY front wheel drive vehicle that I have owned. I have had great results with Michelin Harmony tires......might try the Hydroedge. The other advice that I would give....which you are already doing....READ up....there is a LOT of good information on the internet. Of course....you have to separate the good information from the bad. This can give you pointers on what to keep an eye out for.
Moderator for Ford Windstar room only Links to my pictures, intended as an aid, not a replacement for, a good repair manual. 1996 3.8L Windstar http://www.flickr.com/photos/4157486...092975/detail/ 2003 Toyota Sienna pictures (not much there yet) http://www.flickr.com/photos/4157486...781661/detail/ |
