Old 12-13-2009, 09:11 AM
rodom13 rodom13 is offline
battery drain
my 99 windstar has a new battery and the alternator tests good, but when driving when headlights dim, the abs light has come on, and after turning off the veh it wont start back immeditly. can u please help?
Old 12-13-2009, 10:53 PM
bdahl385's Avatar
bdahl385 bdahl385 is offline
Re: battery drain
Originally Posted by rodom13 View Post
my 99 windstar has a new battery and the alternator tests good, but when driving when headlights dim, the abs light has come on, and after turning off the veh it wont start back immediately. can u please help?
I've seen "NEW" batteries fail within a couple days purchase. I would have the battery, new or not, tested along with the alternator individually at a different place than you've already had your alternator tested. This would eliminate a false positive on the alternator test and verify your new battery.
Assuming that both the battery and alternator test good, I would remove, inspect and clean the typical power cables in your auto. These would be all the red power cables from battery to alternator and battery to starter / power distribution block. Also clean the negative black wires and grounds.
2000 Windstar SE 3.8L 125k miles (mine)
2006 Hyundai Sonata LX 3.3L 108k miles (wife's)
2013 Hyundai Elantra GLS 21k miles (daughter)
Old 12-17-2009, 05:35 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: battery drain
I agree with bdahl, it seems to be a bad contact. Check voltage on battery connectors to see if you have same voltage than batt. It's not a battery drain.
You may need to have terminal cleaned/rubbed and tight connection w/o breaking bolt.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
