Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 12-12-2009, 10:55 PM
Saaby1 Saaby1 is offline
Question Lamp for heat control dark
Just bought a 2002 Jetta 1.8 wagon.
The Misses noted the heat control can't been seen at night.
I would guess there is a lamp for the heat controls and a blub is burnt out.
How would I get to the bulb?
Thanks,
Saaby1
Old 12-15-2009, 05:51 PM
Will308 Will308 is offline
Re: Lamp for heat control dark
Thanks,
Saaby1
You will have to pull the center knob off, just grab it with a pair of pliers and pull it straight out to get to the bulb. I would recommend wrapping the nose of the pliers with something to ensure you don't mar the knob. The bulb is tiny and a real PIA to get to..needle nose pliers are your friend here. I cracked mine on the first attempt to get the old one out. It took a bit of close work to get all the residual glass out as it prevented the new bulb from seating properly.
Good Luck.
Old 01-01-2010, 09:58 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
I use a 5/16" vacuum hose to pull out the old bulb and install the new one.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
