Go Back   Automotive Forums Car Chat > Fabrication & Tools > Machine Tools
Machine Tools Learn about metal lathes, milling machines and CNC tools.
Old 12-12-2009, 01:19 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Fine Threading Experiment
Yesterday I was experimenting with the lathe at work since my lathe doesn't have threading gears. The lathe at work is a 15" swing Clausing Colchester, a big engine lathe. I was curious to see how small it could turn some threads. To my surprise, it cut small threads extremely well using a worn carbide insert. (I need to grind an HSS threading tool for aluminum, this was just an experiment.)
The result was this:
The piece is 3mm (~.120in) in diameter with a .2mm thread pitch (~120 threads per inch) that are .33mm deep. The piece shown was an experiment to replicate the threading on air-jacks in scale, race-damper threading, as well as experiment with threading for center locking lug nuts.
I was very pleased with the result, and I believe the result will be even better with a properly ground HSS tool instead of a carbide threading insert.
-Mike
Old 12-14-2009, 10:29 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Fine Threading Experiment
Looks great, nicely in scale foe a jack. I think it would also look about right for the threading on adjustable shocks. Now, can you cut the interior threads to match it?
I think I'm going to break down and get Sherline's threadcutting gear....
PHOTOBUCKET SUCKS
Old 12-15-2009, 08:08 AM
Decs0105's Avatar
Decs0105 Decs0105 is offline
Registered User
that's what didn't work for me and left me with no other choice than buying some expensive fine thread taps and dies...
Old 12-18-2009, 10:47 AM
mike@af's Avatar
I'm working on grinding a tool in an attempt to cut the interior threads. We'll see how well that works out!
-Mike
Old 02-17-2010, 01:41 PM
Adam Baker Adam Baker is offline
Send a message via AIM to Adam Baker Send a message via MSN to Adam Baker Send a message via Yahoo to Adam Baker
Wow, very nice! Never attempted cutting threads that small. Were you able to ever get the rest threaded so it would go together?
