Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 12-12-2009, 06:43 AM
Gleewee7 Gleewee7 is offline
05 Sonata cut out
2005 Sonata cut out while driving - plenty of fuel. The check engine light came on. Got it started and it cut out a 50 yards later. Any clues?
Old 12-12-2009, 10:43 PM
bdahl385's Avatar
bdahl385 bdahl385 is offline
Re: 05 Sonata cut out
Get the code read and report back. When the CEL comes on, it stores the fault code in memory so that it gives the person with a scanner information on what error code caused the light to come on.
Just don't assume you can replace the part that the error code references. You must still troubleshoot the system to find out what the root cause is. For example, many an oxygen sensor has been needlessly replaced for an "O2 sensor out of range" error code. Many times, this is just a vacuum leak that caused the code, replacing the O2 sensor did nothing to fix the vacuum leak...
Since your car is totally cutting out, I suspect that you are losing fuel delivery or spark. The CEL code should point you in the right direction.
2000 Windstar SE 3.8L 125k miles (mine)
2006 Hyundai Sonata LX 3.3L 108k miles (wife's)
2013 Hyundai Elantra GLS 21k miles (daughter)
Old 04-03-2010, 07:31 PM
dbacon dbacon is offline
Was it a crank sensor?
2000 Sonata, 2.4L 4 Cyl, Auto, Cruise, AC, Pwr windows, Remote mirrors.
Mods:
-Trunk light, internal switch & safety trunk release.
-Removed panel behind rear arm rest to trunk.
-3rd gear i.p. light cycles in 7 colors.
-Fuel low light, now is a blinking red LED.
-"Lights left ON" beeper (Why didn't it have this?).
-Separated the Batt warning from the low brake fluid warning.
-AG 1201 Remote start, door unlock & trunk release.
-Added "Valet" illuminated symbol to i.p.
