Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 12-11-2009, 08:33 PM
cspring cspring is offline
97 Ranger NO HEAT
I have a 97 Ranger 2.3 Liter. I lost my heat just in time for winter. My blower motor works so I figured It was either my thermostat or the temperture control switch on the dash. I got the thermostat because it was only $7.00. Now before I changed it out my thermostat my temp guage would be about half way. After I changed the thermostat which I found in about 4 pieces when I got the housing off my temp guage is reading cold. Any Ideas???
Old 12-12-2009, 10:14 AM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Re: 97 Ranger NO HEAT
Check all your heater hoses, and heater control valve.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 12-17-2009, 03:34 PM
DonSor DonSor is offline
First of all you have a temperature switch instead of a guage. The switch does not tell you what the coolant temperature is, only a range so that if the coolant goes beyond a certain range of temperature it indicates too hot or too cold. To check if the temperature switch is OK, disconnect the wire and turn your ignition on (w/o the engine running). Your gauge should read peg max. Then short the guage wire to ground and it should read minimum. Assuming that your engine reaches operating temperature turn your heater on, blower on high and feel the supply and return hoses to your heater coil. There should be a noticeable difference in temperature. What you find from that is whether your heater valve works or not. Finally, move your heat/cool selector level and see if you are getting any vent changes. This to test if the louvre/s are moving to the right position. BTW what caused the stat to be in four pieces?
