98 coupe hard to start when cold
got real cold the other morning 98 sebring coupe would not start after a while it finally started and ran good for day got in it the next day same thing it started after cranking for a while also had to push on the gas pedal while cranking to get it started. could it be the intake air tempature sensor or the coolant temp sensor or something else like the crank or cam position sensor? oh, and also replaced the fuel filter.
Re: 98 coupe hard to start when cold
replaced iat sensor and it started right up. thought that cured the problem car started having problems starting again. what could it be it is not storing any codes someone said it might be the gas cap.not storing any codes, car will not start now. fuel pump seems to be working spark plugs are wet.think i got this time replaced distributor and it started right up
