Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-10-2009, 11:01 PM
daslieben daslieben is offline
2001 Sl2 1.9 DOHC Burning Oil
I understand that these engines are notorious for burning a lot of oil does anyone know the common cause? I have no leaks, the plugs look fine, runs fine, and its been burning oil for a few years. Maybe a couple of quarts between changes. Has anyone had any success with lucas/stp treatments etc...or are they a waste of time??
Old 12-11-2009, 05:36 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: 2001 Sl2 1.9 DOHC Burning Oil
The additives are a waste of time. A very short simple description of the problem is that oil accumulates in the combustion chamber because of the bad piston/ring design and gets burned. Rebuilding the engine with revised pistions/rings is the only solution to the problem.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 12-12-2009, 07:53 AM
thanks for the response, other than ring replacement I guess the only option is to keep a six pack of oil in the trunk. I was pretty sceptical of that magic oil fixes anyway. What's the life span on this engine having the ring issue assuming I keep the oil topped off etc...Currently I have a 150k on the car?? Could I get another 75 to 100k off the car without a rebuild?? Honestly if it doesnt I'd be happy with the service the car has given me anyway.
Old 12-12-2009, 11:36 AM
Ruley73's Avatar
As long you maintain it well and keep the oil level up, you should easily get another 75K or 100K out of it. Many people do just that and easily exceed 300K miles.
My rides:
- Steve Smith (Red)
Old 12-16-2009, 10:49 PM
RC1488 RC1488 is offline
A couple of quarts? Thats pretty bad.
Try a Marvel Mystery Oil soak. I have posted a how to for this as a thread. Its not a total fix, but it does sometimes loosen up the oil control rings.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 12-17-2009, 06:47 AM
Thanks for the response, 2 quarts may be a little bit of an overstatement, I don't have the best history of changing the oil every 3k, so it's a guesstimate. I found the how to for the Mystery Oil soak, I'll give it a try. I broke down and bought some lucas treatment, it was on sale so what the heck. It seems to help, but it's a result of the viscosity. It's like adding vaseline to the oil mixture or putting gum to cover a hole in a dam. How difficult is the ring replacement in this car? I'm going to try and stay away from it, every time I do something like that to a car I tend to create another issue, I'm not the most precise do it yourself-er.
Old 12-17-2009, 09:54 AM
A ring replacement = Engine rebuild. Its easier and cheaper to get another junkyard engine and drop it in.
Old 12-18-2009, 07:19 AM
plymouthsrock plymouthsrock is offline
Of course, it's a crapshoot whether the junkyard engine burns any less oil. Mine goes through a quart every 500 miles, and will end up in a yard soon, no doubt.
Old 01-30-2010, 08:16 AM
adb140275's Avatar
adb140275 adb140275 is offline
Send a message via AIM to adb140275 Send a message via MSN to adb140275 Send a message via Yahoo to adb140275 Send a message via Skype™ to adb140275
yeah ive heard of seafoam and marvel piston soaks, and ive also heard that the valve seals are to blame.
Old 04-02-2010, 08:02 PM
pencilneck0 pencilneck0 is offline
those so called oil treatments are a bunch of nonesense! lets face it the rings are stuck and full of carbon and cannot do there job.(poor design) I own a 1999 sw2 that has this problom I have 60000 miles on it and it will burn a quart every 500 miles what a piece of junk it is!
Old 04-03-2010, 05:11 PM
Cat Fuzz Cat Fuzz is offline
You don't comprehend much when you read, do you? What we are talking about is using Marvel Mystery Oil and soaking the rings with it to loosen the gunk that inevitably builds up around them. Usually the gunk can be avoided by using quality motor oil and keeping up on oil changes. Something most people do not do. Yes, drilling drain-back holes in the pistons is something Saturn failed to do but, again, the problems can be avoided with proper maintenance.
I'd be happy to buy a vehicle just like yours for $500. The MMO soak usually works the first time but could take multiple treatments.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 04-03-2010, 07:00 PM
Hey dummy , I have already tried multiple "MMO Soaks " the oil cunsumption increased after the soaks. Do you Comprehend?
