Old 12-10-2009, 11:30 AM
ZiggyPA ZiggyPA is offline
Question ball joint replacement questions
I need to replace the front ball joint (passengers side).
The autozone guide is not completely clear.
Do you need to remove the caliper and/or hub assembly?
How long would ball joint replacement take on average?
I see now that the ball joints need to be greased but in what interval?
Thanks
Old 12-10-2009, 12:28 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: ball joint replacement questions
I presume this is a newer front wheel drive PA, and not an ancient rear wheel drive one, right?
Yes, the caliper and rotor should be removed, to give more room to work.
Unbolt the caliper, but you do not have to remove it from the flexible line. Use a piece of wire or string etc to tie the caliper out of the way. Don't let it just hang by the flex line, since that can damage the line.
The last time I did one, I also unbolted the steering knuckle from the strut, and removed the drive shaft. (front wheel drive)
For an old rear drive car, there is no strut or driveshaft to remove. But you should support the lower control arm with a floor jack before separating the joint, for safety.
I usually grease all fittings, including the ball joints at every engine oil change, so every 5000 to 8000 km is fine.
Be sure to grease the new ones after you have installed them. Don't over-grease them, you do not want to rupture the new grease seals. Grease them just enough so that you can see the grease seal 'swell' a bit.
Old 12-10-2009, 01:57 PM
It is a 91 front wheel drive indeed.
I see Rockauto sells several brands of balljoints, with varying prices. Is Mevotech a good brand ?
Also are there any non metric sizes in this replacement except for the caliper bolts?
Old 12-10-2009, 04:47 PM
MagicRat's Avatar
All the fasteners should be metric.
IMO go for a name brand, like Raybestos or Moog. Chances are, they will last much longer.
Is there some reason why you are not changing both front joints? Usually if one is gone, the other is not too far behind.
Old 12-10-2009, 05:35 PM
Jrs3800 Jrs3800 is offline
Get the Moog or TRW Ball joint...
If they have never been replaced before and are still stock you'll have fun drilling and grinding the hardened rivets... Do both sides and then have the alignment reset..
Old 12-10-2009, 06:24 PM
so instead of the 3 bolts I see on the Rockauto ball joints replacements, originally the ball joint is held in place by 3 rivets?
Old 12-10-2009, 06:28 PM
Smile Re: ball joint replacement questions
If the Ball Joint is original to the car it will have Rivets, hardened at that...
The replacements will have Bolts...
Old 12-10-2009, 06:37 PM
Ok thanks !
But if the original ball joints last almost 20 years, how long will the cheaper brands last?
Old 12-10-2009, 06:39 PM
MagicRat's Avatar
Forgot to mention the rivets. Grinding them off (without ruining the control arm) is the worst part of the job.
I found I could carefully grind off 90% of the rivet head, then knock them out with an air chisel ( a punch and big hammer will do it, too.
Old 12-10-2009, 06:51 PM
And can this be done without realigning the wheels? Alignment is perfect now, and my experience is, nobody ever greases the tie rods overhere so they all have to be replaced.
Old 12-10-2009, 09:02 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Alignment can not be "perfect" with worn ball joints!
Old 12-11-2009, 06:23 AM
I understand what you're saying, let me put it differently, the car still drives perfectly;-)
I checked the prices overhere:
ACDelco $225
Moog $120
Old 12-11-2009, 06:44 AM
HotZ28's Avatar
AF Moderator Elite
Well with that much difference is price, the selection is a no-brainier! Moog is probably superior to ACDelco these days! I just installed Moog sway-bar bushings & end-links on my PA with 'blue' polyurethane bushings; man what a difference that made in ride & handling!
Old 12-11-2009, 01:17 PM
I think the ball joint is still original and has rivets. How long would replacement, on average, take?
Also does anyone have the alignment data (camber, castor, toe) for a 91 PA base model?
Haynes just states that you should have professional alignment equipment which isn't very helpfull at all (again..)
Old 12-12-2009, 02:26 PM
RT Jam RT Jam is offline
The alignment was probably good some time ago. The ball joint wears. You lose a bit of alignment. You replace the worn part with a good new one. I'll tell you 99 out of 100 times. You alignment will be restored back to original.
I'm another one who can't rest until I know it's right and 50 - 150 dollars later EACH time. The alignment after replacing parts is right on.
I'm not talking about replacing eccentrics and parts that hang onto slotted holes like the old cars but if you replace anything NON ADJUSTABLE, it's probably ok.
As for the grease interval. Every oil change will be sufficient.
65 Plymouth Belvedere
69 Dodge Super Bee
87 Dodge Ram
93 Ford Mustang 5L
00 Buick Park Avenue
