Spindle nut torque spec
Hey everyone I need the spindle nut torque spec, I torqued it to 150ft lbs last night and did some looking around online and I've seen some places say 155-210 ft lbs I'm hoping one of y'all can give me the right torque.
1998 K1500 Z71 5.7L Vin R Thanks |
Re: Spindle nut torque spec
Was you replacing the bearing?
I basically rebuilt the whole front end. Brake pads, rotors, passenger side half shaft, seals and bearings in front diff, and both hubs. I'd like to think she's ready for another 200,000.
The new wheel bearing usually have the axel nut torque specs in instruction sheet. And do not forget to torque the axel lug nuts. Good luck
I got the hub assemblies from O' Reilly's and they was nothin in the box which I felt was odd, But it did have a big sticker on top the box sayin do not use impact as a torque wrench...lol
If you have the axle lug torque I'd take it I just put them as tight as I could with a wrench |
Remember proper testing gives us the answer to many problems. MT Last edited by MT-2500; 12-10-2009 at 11:09 AM. Reason: broken link |
on the 2000 silverado/tahoe the spindle [hub] nut is listed as 155ft lbs..
I would say your good... I would put some med lock tight on the nut if it is not new nut.. |
6 and 8 wheel lug nut is listed as 140 ft lbs...I usually torque to 110ft lbs . then repeat after driving for a day... |
