Old 12-09-2009, 08:53 PM
mustardstain mustardstain is offline
99 jeep cherokee oil sensor
I have had to replace my oil sensor about 3 times over the past year. I am not sure what is wrong because I had the oil pressure checked while the check engine light was on and my oil pressure was fine. They recommended changing the oil pressure sensor so I did just that. Everything was fine until a few months later when I had to change it again. Happened again a while later. Now the engine light is on again and I don't want to change the sensor again until I try to find out what is blowing out the sensor. Any ideas????
Old 12-13-2009, 10:18 AM
mtulett1 mtulett1 is offline
Re: 99 jeep cherokee oil sensor
oil pressure is not the issue when the check engine light is on...only when the check gauges light is on. I would put it on the code reader and see what that check engine light is on for. Good luck man.
