Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 12-09-2009, 05:56 PM
Electra8 Electra8 is offline
2005 Tahoe Traction Control Light
When taking off from a stopped position, the traction control light comes on and the vehicle acts as if power has disengaged. Vehicle can be warm or cold. Weather conditions can be wet or dry. Problem is so intermittent that a service code won't register. Any suggestions?
Old 12-09-2009, 10:12 PM
roadrunner2 roadrunner2 is offline
Re: 2005 Tahoe Traction Control Light
When wheel slip is detected, the Electronic Brake Control Module (EBCM) will activate the traction control mode.
A signal is sent from the EBCM to the PCM (Powertrain Control Module) commanding less torque to the drive wheels.
Torque is reduced by retarding the ignition timing and by controlling the throttle control actuator.
I don't know if that will help or not.
The problem with doing nothing is not knowing when you're finished.
Old 02-04-2010, 09:59 AM
Silvio99 Silvio99 is offline
Has anybody gotten to the bottom of this problem? I have the exact same problem and my car wil go out of (extended) warranty soon. Since this is intermittent, does anybody know of a way to "cause" this problem for the service tech?Thanks for your help!
Old 02-04-2010, 01:13 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Check all wheel speed sensors for reading the same.
If a tire spins or a speed sensor if off from other side it trips Traction control.
MT
Old 02-22-2010, 02:41 PM
deaaa deaaa is offline
Just wanted to know if you fixed the problem yet and what was bad?
