Old 12-09-2009, 05:14 PM
pontiacfanactic pontiacfanactic is offline
2003 s-10 shift problems
Having problem with push button 4x4 that is not locking the front wheels in. Is there a fuse or other easy fix. Do hear the thunk at times but other times do not hear nothing. Do you think it is the differential transaxle or a vacuum leak. Please respond ASAP as it is cold and snowy out side.
Old 12-09-2009, 05:32 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2003 s-10 shift problems
Is front drive shaft locking in?
If so check the front axel actuator for locking in front axels.
The front actuator under battery box locks in front axel.
It uses vacumn and a cabel and electrical switch.
See if this link helps.
http://www.automotiveforums.com/vbul...d.php?t=572914
Let us know how it goes.
MT
Old 12-09-2009, 05:36 PM
MT-2500's Avatar
AF - Advisor
What transfer case?
Does the shift buttons have a AUTO 4W button?
DOES ALL SHIFT BUTTONS LIGHT COME ON FOR A KEY ON BULB CHECK AND THE WORK RIGHT WHEN YOU PUSH SHIFT BUTTON?
ANY BUTTON WITH FLASHING LIGHTS?
MT
