Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 12-09-2009, 12:30 PM
robw2421 robw2421 is offline
keyless entry
I have a 2006 montana anyone tell me howi can program a new key bop
Old 12-09-2009, 09:48 PM
roadrunner2 roadrunner2 is offline
Re: keyless entry
If you have a programmed remote now and want to program a second remote, all you have to do is follow the instructions in the (vehicle) owners manual.
If you do NOT have one already programmed, you'll have to go to the dealer.
The problem with doing nothing is not knowing when you're finished.
Old 12-20-2009, 01:07 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: keyless entry
You have to program all remotes at one time. Pretty much a dealer service, but call around as I have found the price can vary greatly between dealers.
Remote Control Door Lock Transmitter Programming for 2006 Uplander/Montana SV6
Important: All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence.
If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
1)Install a scan tool.
2) Use the scan tool in order to access programming: Vehicle Control System/Computer Integrating System/Module Setup/BCM/Program Key Fobs.
3) Press the START soft key on the scan tool. Important: The scan tool must stay connected until all of the transmitters are programmed.
4) Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds, the scan tool will indicate that the transmitter is programmed.
5) Repeat the previous step in order to program up to 4 transmitters.
6) Remove the scan tool.
7) Operate the transmitter functions in order to verify correct system operation.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
