Old 12-09-2009, 10:48 AM
hinrichsscott hinrichsscott is offline
08 Grand Caravan TPMS?
What is the true info on the Caravan TPMS? I had a tire valve stem go bad on an 2008 Grand Caravan, standard wheels/tires and the dealer replaced it as well as the sensor (all under warrantee) but this made me wonder what is true about this system (I've looked on the net and get conflicting/incomplete info). So here are some questions:
How long do they last?
Do they run off a battery? (I would think they'd have to).
Can you replace the battery when it dies or do you have to buy a new sensor?
When getting new tires do you have to replace the sensor?
Can you replace the valve stem seperately from the TPMS sensor?
Should you still replace the stem when getting new tires?
Are the sensors specific to each position on the car - if I rotate the tires will I have a problem?
If I eventually buy aftermarket sensors will they work?
What would I have to look for in aftermarket sensors (are there different frequencies?)
Are all 08 Caravan sensors the same?
Will I have to "reprogram" the sensors or the car if I buy new sensors?
Can a shadetree mechanic reprogram the TPMS or does this require the dealer?
Any help would be greatly appreciated.
Old 12-09-2009, 11:38 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 08 Grand Caravan TPMS?
[quote=hinrichsscott;6076106]
The expected life is 5-8 years. I have replaced some that have been less and we can expect some to last longer. I would probably guess that it has to do with how long you drive (not necessarily how for) since the sensors are more active while the vehicle is in motion and less active when the vehicle is stopped for an extended period.
-Yes
-I am not aware of any that the battery is serviceable.
-No
-Some you can some you cant
-There are service kits that contain all the seals and parts needed to "reseal" the sensor to the wheel. The manufacturers may or may not recommend these with tire replacement.
-your owners manual will explain that
-If they are made for your vehicle. We get aftermarket sensors when available and they have worked just fine for there applications
-They should be listed as compatible with your vehicle.
-Manufacturers may have different sensors for different wheels (steel wheels may require a different stem angle than an aluminum wheel)
-I don't know for sure on your specific vehicle
Tags
2008 , caravan , pressure , tire , tpms
