94 olds 98 sat, ran, wont start
Hello,
I have a 1994 olds delta 98 regency elite. It sat for about 2 years. Put in a new battery, started right up! Ran it for a few minutes a couple days over a couple weeks. It had 1/4 tank of old gas. I came home one day with fresh gas, a one day permit for AirCare, dumped in a gallon and now it won't start. I changed the fuel filter because I thought I might of ran it too low on the old gas. What should I try next, how can I clean the injectors?? Thanks for your time and suggestions. -Kevin. |
Re: 94 olds 98 sat, ran, wont start
Could be old gas is still in there, drain it at the fuel filter hose .Could also be water in there,use gas line antifreeze also try injector cleaner after you put more than 1/2 tank of gas so fuel the pump is covered.1 gallon is not enough.
Good luck
1999 Buick Century Custom 3.1L , 148,000km. 2000 Toyota Echo, 1.5L 220,000km Last edited by dreager; 06-30-2010 at 07:42 PM. Reason: more info |
