Old 12-08-2009, 10:42 PM
papa duke papa duke is offline
Power trunk release
Just bought a 98 Lumina that has a trunk release button on lower left dash panel that is not wired. Did all Luminas have this button, although Power Trunk was optional? The trunk latch has no solenoid, but some type of wired black plastic release. I would like to hook up a power release. Any thoughts and answers would be appreciated. Thanks.
Old 12-13-2009, 02:15 PM
Blue Bowtie's Avatar
Registered Offender
Re: Power trunk release
The knee bolsters are prone to breakage. It may be that someone installed a used, color-matching bolster and it happened to have a trunk release. The lack of a solenoid in the trunk is a clue.
Old 12-13-2009, 08:23 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
I'd guess the power drop in the wiring harness is there, even if the option wasn't.
See if there's an unused pigtail in the trunk wiring, then try to find a corresponding one in the dash. If that's there, all you'd need is the kicker for the release, sounds like...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 12-15-2009, 12:33 AM
therapyreject therapyreject is offline
Send a message via AIM to therapyreject
The power drop is there. Or at least it was on mine, no reason it wouldnt be for yours too.
Since you already have the button itself, just go to a junkyard, find the solenoid for the trunk (and the bolts) and bolt it right on. Then just plug it in. It was a lot easier than I thought it would be, it literally just bolts into place and plugs in. The wires are tucked away in the trunk lid and under the dash and if I recall, theyre black and white.
Was one of the first "upgrades" I did to mine, and for $5-10 in parts its well worth it.
