Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 12-08-2009, 09:55 PM
locmj locmj is offline
light problems
I have 99 venture that has no tail lights or dash lights. the running lights work until the headlights come on and the running lights go out and the tail lights don't come on and all we a have the headlights. I have checked the fuses and checked the boards in the rear lights I didn't see any burnt marks or anything is there something else I should be looking for. Can the board be bad without showing signs? is there anyway to test them?
Old 12-10-2009, 06:44 PM
Re: light problems
Also the chime that usually goes off when the lights are left on or the key is left in the ignition keeps chiming every time the drivers door is opened with no key or lights on?
Old 12-14-2009, 09:21 PM
gearhead514.2008 gearhead514.2008 is offline
Re: light problems
I think I can help you with your lighting problems. The Chevy Venture and the Pontiac Montana are the same van and they share all the same problems that were created by GM's genius engineers. I have replied to other threads in this column about the same problem, so you can look deeper to find a more thorough explanation and fix for it. It might be in the Pontiac Montana column too. Just look for my user name under light problems. I will give you the readers digest version. I am 90 percent sure your problem lies in the wiring bundle that runs across the floorbard in front of the driver and passenger seats. Do your power windows and locks act up sometimes? All of these wires that run the taillights and power options are in this bundle of wires mentioned above. You must remove both front seats and pull back the carpet from the front of the dash to about where the seats were. There you will see a black wiring enclosure. If you cut off all the tape and take the wires out, you will see there are about a dozen or so connections where 2 or more wires come together into a splice joint that is covered by black duct tape. Remove the black duct tape on all of these splice joints and you will see the green ooze known as corrosion. Probably most of the wires fell apart while removing the black duct tape. Try to remember where they go. You will have to fix each one of these one by one. First cut back the infection(corrosion). Strip back the wire until you find good wire. You might have to add some wire. Crimp these together with a new crimp connector and heatshrink the splice joint afterwards unless you want to do it again in 50,000 miles. This should fix all of your wiring issues. Make sure you get all of them. There are a few on the passenger side that run up to the dashboard as well. Get them all and then tape everything back up. What happens is water from snow or rain soaks through the carpet from your shoes, a leaky windshield, or a heater core leak and gets into the wiring. Spilled soda drinks work quite well also. This moisture gets into the tape and then corrodes the wiring because there is just a piece of duct tape protecting the crimp. GM needs to learn how to seal the exposed wiring if they are going to put it directly beneath your feet. This happens on all of their vans. I laugh everytime I see one of these vans go down the road and the back lights blink and light up like a Christmas tree. When they add the blinker, its a real light show. Anyways, I hope this helps you. If you have any more questions, feel free to ask. This is something you can do yourself. If you take it to a garage they will charge you $88 an hour and they will only fix what is corroded, leaving future problems.
Last edited by gearhead514.2008; 12-14-2009 at 09:25 PM. Reason: spelling and structure
Old 12-17-2009, 11:38 AM
henry10 henry10 is offline
Re: light problems
If the fuse is ok, you should get a copy of the Chassis Wiring Diagram and a voltmeter to trace the path, and also to give you an idea where the ground is for that specific circuit. Sometimes, taking shortcuts to diagnosing works, but in most cases your quickest way to fix it is to take the long way.
Old 12-18-2009, 08:00 PM
Re: light problems
well I checked all the wires I could find under the carpet and could not find any corred wires?
Old 12-18-2009, 11:00 PM
Koolmist Koolmist is offline
Re: light problems
I have the same exact problem with a 1989 Chevy S-10 Blazer.. I will check under the carpet tomorrow because I do have a moon-roof leak so this may be my problem.. I will post an update after..
Old 01-15-2010, 01:13 PM
Re: light problems
Never could fix the lights some days they work mostly not. Called the stealer today ask for a ballpark amount or time it would take knowing this is a common problem on all gm's, I was told they charge 80 just hookup to dianostic machine and then we will go from there since he had never heard of this problem??? Is there any thing else I can try before I take it to the stealer?
Old 01-15-2010, 02:02 PM
merc81 merc81 is offline
Re: light problems
You said the 'boards' didn't look bad in the taillights, but what about the connector that plugs into them? That's where the problem lies, not in the circuit boards, but in the connnectors that plug into them. Unplug both lights in the rear and then try the headlghts, running lights on the rest of the car while the tail assemblies are unplugged.
If things are still wierd/not working then I'd vote for the connector under the passenger side carpet area in front seat. I'll be pretty surprised if its not the rear light connectors however.
Old 01-15-2010, 06:33 PM
lesterl's Avatar
lesterl lesterl is offline
Re: light problems
Check your grounds, they get bad as well. Hooking the van up for a "diagnostic" probably wont tell you much, waste of $ IMHO.
Old 01-15-2010, 06:44 PM
danielsatur danielsatur is offline
Re: light problems
I would check www.alldata.com ,and the Body control module.
Old 01-15-2010, 10:08 PM
Re: light problems
You should use a meter to measure voltage. Additionally, you should also get a continuity meter to check for problems. These are inexpensive tools and in conjunction with the Wiring Diagram you should be able to fix it. It may seem overwhelming at first, but it is really logical and straight-forward. It will save you a lot of money and time.
"95% of the times it is the obvious cause"
This Forum is your best friend. Your other best friend is Google Search.
