Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 12-07-2009, 06:40 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
What's the torque on the plastic intake manifolds
What's the bolt torque on the plastic intake manifolds for the 4.6 L 1996 and newer?
http://cmasalvage.com/96cv_imr3.jpg
http://cmasalvage.com/96cv_imr4.jpg
Mike aka JYD
Old 12-07-2009, 09:28 PM
Kitt1993's Avatar
Kitt1993 Kitt1993 is offline
Re: What's the torque on the plastic intake manifolds
Hi Mike, I think this is it, but not sure..
Intake and side plates assembly to cylinder head
--Step 1 15-22 ft/lbs
--Step 2 Tighten additional 90 degrees
Intake manifold to cylinder head bolts
SOHC (two valve GT and bullitt) 15-22 ft/lbs
DOHC (four valve Cobra and Mach One)
Upper plenum to intake 71-106 in/lbs
Intake to lower side plates 71-106 in/lbs
--Step 1 15 ft/lbs
Nick names for my Car....
Abe Lincoln, opcorn:
The President,
Lucky Number 5
Old 12-08-2009, 06:01 AM
I've had a bunch of trouble with these leaky intake manifolds here lately. The plastic 96 one has been replaced with after market, and is of poor quality in my opinion. It was warped and had to run my jitter bug sander down each side to flatten it out. Auto parts store kept saying that the old style gaskets were the correct ones. They wanted to sell me the whole manifold for 250. Ended up finding the correct set yesterday at the next place I tried. I needed the individual round ones, not that plastic strip for the aluminum manifolds. Well 15 to 22 ft lbs sounds right, but don't know if I like the additional 90 degrees. What's up with that ? I just hate to over torque something like this.
Mike aka JYD
Old 12-08-2009, 01:15 PM
Kitt1993's Avatar
Probably for high performance. Not sure though Mike,. Call up Advance Auto Parts, and ask them to check the specs chart. They can tell you.
The President,
Lucky Number 5
Old 12-10-2009, 09:17 AM
I am going to go with 22 ft pounds of torque. Any one got a picture of the bolt torque sequence?
Got the wrong old style gaskets at first, Advance auto. They were dumb founded as what gasket to use. Wanted to sell me a new intake manifold for 250. Went down the street to O Reilly's to get them ordered. Advance auto parts is clueless on this one.
Http://cmasalvage.com/4.6l_gaskets1996.jpg
Http://cmasalvage.com96cv_imr5.JPG
Mike aka JYD
Old 12-12-2009, 02:29 AM
Towncar's Avatar
Towncar Towncar is offline
[quote=junk yard doggie;6076608]I am going to go with 22 ft pounds of torque. Any one got a picture of the bolt torque sequence?
[quote]
http://www.autoclinix.com/Manifold6.htm
COPYRIGHT BELONGS TO AUTOCLINIX, CLICK IMG TO GO THERE
-Steven
1996 Town Car, Cartier
Old 12-27-2009, 10:05 PM
22 pounds is way to much torque. The last bolt snapped off in the head at 22 ft pounds. I had to take the intake back off and remove the broken fastener. Was just enough bolt sticking out to grab with vise grips. I went about 19 ft pounds the second time around.
Mike aka JYD
Old 12-27-2009, 11:05 PM
Towncar's Avatar
Originally Posted by junk yard doggie View Post
....22 pounds is way to much torque....
....I went about 19 ft pounds the second time around.
I did mine like it says in the AutoClinix process at Step #33, 18 FT LBS.
That was 20k miles ago, over three years... not my daily driver
Mine didn't have the built in gaskets though, I used the FoMoCo version with seperate gasket plates...notice the manifold surfaces are flat, no gasket groves.
-Steven
Old 12-28-2009, 12:22 AM
Kitt1993's Avatar
Steven, I noticed in your 3rd pic, that you have exactly 1 penny and 1 dime. A total of .11 cents. May I borrow .11 cents from you? lol Nice pics of your engine. I did my intake a yeara and a half ago. Not to bad once I go the EGR valve off. (Solid Aluminum Intake)... Good to see you back at the Forum!!! I think we should have National Steven Day here at the Forum.
I'll bring the beer!!!!!!
Mike can bring the food
And MacGiver can bring the bad jokes.
The President,
Lucky Number 5
Old 12-28-2009, 06:47 PM
Towncar's Avatar
I think Mike's gonna kick your ass first for the 22 FT# note, then mine for not speaking up sooner
-Steven
Old 12-29-2009, 11:41 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
I did the intake swap 3 times now and each time I torqued to 22 lb-ft. without problems. I do inspect the bolts before reinstalling though and noticed that some were stretched out and weakened for some reason. I replaced with some from the hardware store and works great.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 12-29-2009, 11:44 AM
I have a secrete recipe for a mean barbecue sauce. Not for little girls or wimps, lol.
I'm fairly sure I am dealing with an after market manifold on this car. It says made in USA but no Ford part numbers. According to maintenance records on the car from the previous owner, the manifold was replaced in 2004 Due to being cracked. Check out their prices on this repair. 573.00 for the manifold and gaskets, 101.67 for the belt and coolant. 390.00 in labor.That's a total of 1064.67 And it gets worse, O by the way your trans is shot. The total bill is for $3100.00. Somebody got hosed on that one.
Got it all back together and no leaks so far. That's interesting that Steve's plastic manifold is flat on the gasket surface. When I was at advance auto I had them checking a bunch of model years for the right type of gasket I needed. I had them check from 96 to 2005 4.6L and still they couldn't pull anything up. What do you guys think, is the individual gasket an after market thing? Steve is your manifold the Ford Up graded one?
I haven't messed with the 98 TC I have in a while. It has the plastic intake as well. It has some of the same problems as this 96 developed. So I have feeling that I will need to do some of the same repairs to it. I'll take a closer look at the gaskets on that one. I should be able to tell, since that plastic gasket frame can be seen beyond the intake manifold edges.
I must say the relocation of the egr valve to the center of the manifold in 96 makes this job much more enjoyable. The old style just sucks, to work on.
Mike aka JYD
Old 12-29-2009, 12:04 PM
Bolts all looked good not rusty or anything, that one I snapped off must have been week. When the bolt snapped off, I did have to walk away for a few minutes to compose my self. There were a few obscenity's mentioned. For some odd reason the bolt was easy to remove. I thought I might have to spend all day drilling it out of the head. I got lucky on this one. I can see there would be many different torques for the type of gasket, and type of intake.
Check out the nice rat nest under the manifold on this car.
http://cmasalvage.com/96cv_imr1.jpg
Mike aka JYD
Old 12-29-2009, 12:09 PM
I did break a bolt one one of the swaps. It was the original install from the factory which is what surprised me. I had to do the same thing, walk away and grab some lunch. But came back, sprayed some PB Blaster on it and let it soak for a few minutes. Then I realized I could turn it out by hand.
Here's what it looked like http://richgannon.info/gallery/displ...e.php?pos=-427
Old 12-29-2009, 04:55 PM
Towncar's Avatar
Yep, I got mine from a dealer in Arizona. I may have the PN somewhere, I don't recall offhand what it was.
Found it:
F8AE-9424-CA
-Steven
