Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 12-07-2009, 06:35 PM
nhorn1983 nhorn1983 is offline
Question couple questions on my 97 riviera
i had to unhook abs sensor underhood cause everytime u go to take off not stop either traction or abs would surge on any ideas what needs to be fixed... next hard shifting and vibration on take off mount or something more.. also heater only blows hot out on 90 anything else its cold any ideas thanks
Old 12-07-2009, 06:52 PM
maxwedge maxwedge is offline
A990 racer
Re: couple questions on my 97 riviera
The abs should be scanned for codes and sensor inputs. The vibration on take off needs onsite road testing to pin that down( mounts, axles, misfire), the trans issue could be many things, engine tune, skewed tps, bad trans pressure control solenoid to name a few.
Old 12-07-2009, 09:30 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Blend door out of calibration, broken gear in actuator or, clogged heater core, stuck thermostat, poor coolant circulation, just to name a few.
