Old 12-07-2009, 01:27 PM
bandoliero bandoliero is offline
HELP NEEDED, Best Wiring options for Amp & subwoofers needed?
Hi all How you doing!
Thought I would make use of the Forum, after a long time of reading up!
Basically I have:
Amp : Audibahn amplifier model a2300 HCT
subs: Kicker 15" L7's x2 & these are the 2 ohm dvc versions
my car: e38 bmw 7 series
& am Unsure How to wire these up? As I am not all up there in maths, Not sure if my Amp is 0.5ohm capable, as it not stressed in the specs!
serial? parrallel?
space in my boot will be an issue, shall I stick with seled boxes?
Would ideally like to run them at atleast 1 ohm or if I have to 2ohm load!
BUT I am unsure what to do? So please share your thoughts with me please!
Thank in advance...
(If I can supply you with any more info please let me know, never wanna post links of manufactures unless I had too!)
Old 12-07-2009, 02:15 PM
Re: HELP NEEDED, Best Wiring options for Amp & subwoofers needed?
Amplifier SPEC:
4800 Watt 2 Channel High Current Amp
2400 watts MAX x 2 @ 1 ohm stereo
1200 watts RMS x 2 @ 1 ohm stereo
600 watts RMS x 2 @ 2 ohms stereo
300 watts RMS x 2 @ 4 ohms stereo
4800 watts MAX x 1 @ 1 ohms mono
2400 watts RMS x 1 @ 1 ohms mono
Kicker subwoofer specs:
Model Solo-Baric L7 15
Size (IN.,CM) 15, 38.1
Impedance (OHMS) 2 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 2000/1000
Sensitivity (dB 1w/1m) 89.4
Frequency Response (Hz) 18-100
Old 12-07-2009, 06:22 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
if you wire up both of the coils on each of the sube in parallel, then both subs in parallel, you will have a .5 ohm load. Only way to tel if it will work is try it. If you get a warning light, wire the 2 subs in series. Looks like you will take a pretty good hit in power with anythinmg less than 1 ohm mono.
Old 12-07-2009, 06:29 PM
Originally Posted by PaulD View Post
if you wire up both of the coils on each of the subs in parallel, then both subs in parallel, you will have a .5 ohm load. Only way to tel if it will work is try it. If you get a warning light, wire the 2 subs in series. Looks like you will take a pretty good hit in power with anythinmg less than 1 ohm mono.
Everythings NEW Boxed, But not in warranty anymore, as its been sitting in my house for AGES!
Even the subbs ave not been run in yet!
I guess I only have 2 options:
0.5 ohm load & or 2 ohm load! is there no wiring that sets me up with a 1 ohm load?
when you talk about the pretty good hit in power, Do you mean:
I need to uprate my alternater, & big 3 wires?
Old 12-08-2009, 06:16 PM
Audio Guy
what I mean by hit in power is that you only get like 1/2 power at 2 ohms. There is no way to connect 2 dual 2 ohm subs to get a 1 ohm load.
