Nothing but 2wd
So tooling around on my 05 Trailblazer this weekend i found out the hard way that my 4wd don't work in fact AWD,4HI and 4LO dont work the selector lights on the switch are moving fine but it just stays in 2wd but after messing with it for awhile it did finally work one time to get me out of the mess i got into
any ideas? Thanks Last edited by dedeisel; 12-08-2009 at 09:51 AM. |
Re: Nothing but 2wd
Many things can cause this, the dash switches were problematic and on 2002-2004, the transfer case encoder was also an issue.
Re: Nothing but 2wd
Everything seems to be functioning other than the actuator on the front diff seems as if though its not pushing all the way in
Re: Nothing but 2wd
Is the ft driveshaft driving the ft diff but the axles are not locked?
Re: Nothing but 2wd
Yes the drive shaft is turning into the diff but it's not locking. If I take the actuator out of the diff and push the plunger in it locks no prob, so i dunno if it's a actuator prob or a calibration prob?
Derek |
Re: Nothing but 2wd
Could be the actuator or even the transfer case encoder which was a more common issue. For a proper diagnosis a factory manual should be used for troubleshooting.
Re: Nothing but 2wd
Got a hookup for one by chance?
Re: Nothing but 2wd
whats tran case encoder? thanks
Re: Nothing but 2wd
Re: Nothing but 2wd
Ok, the transfer case encoder is the device on the transfer case that engages the front driveshaft and selects 4h, and 4l as well as 2h. It is electronically controlled.
