Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 12-07-2009, 10:06 AM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
boost ideas
ok i have a turbo under my bench that was on a running car about 5 years ago so i want to put it on my neon questions are
1 how much boost will the basically stock motor take (this turbo only makes like 7 psi max i think but i want to keep it conservative stay in the 4to 5 range)
2 what can i do about the ecm , will the mopar ecm work for this if not what will that wont kill my wallet or be complicated
3 what kind of gain should i expect from 4 to 5 psi (will it be worth all the work) ---i have a 2001 rt head with some port on the stock bottomend (140XXX miles) work an atx tb and no egr valve
4 not a question im doing a home made turbo type deal to save money on parts i have a few ideas already going into play on how to hook it all up just need some info on tunning and the motors durablity
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 12-08-2009, 06:47 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: boost ideas
On a healthy stock engine, the block and pistons can handle about 8 psi. You will need what is called a "missing link" to keep the PCM from seeing boost. If it sees it, it will freak out. I don't know anyone running 4-5 psi, but around 7-8 psi you could see about 225-250 HP total.
2003 Dodge SRT-4
Old 12-08-2009, 07:31 AM
Re: boost ideas
so this all may be easier than i think
so is 7-8 psi safe for daily use
and the "missing link" you mention is this a theoretical thing or what i know other injected cars need different map sensors but not a clue on this car this is the only part that stumps me i tried Google with little luck i did see something about running boost on the stock dohc n/a ecu on a sohc motor but i don't know how reliable it is and cant find it again didn't say any thing about the map tho
Old 12-08-2009, 08:00 AM
Re: boost ideas
You can either use a missing link or a MAP clamp. Either one will keep the PCM from seeing the boost.
And yes, you can realiably run 7-8 psi on a daily driver.
2003 Dodge SRT-4
Old 12-08-2009, 11:00 AM
Re: boost ideas
ok i been googleing and found lot of info the map clamp ive actually made one before ill have to find it also i found a way to test the wastegate to see how much boost it will make i got about 6 psi so its close any insite on the dohc n/a ecu running on a sohc motor also will the factory ecm keep up
so in the end of running back and fourth checking numbers and such i think ill be able to do this pretty cheap im thinking with out the mopar ecu 150 to 200 bucks (depending on what parts i can scavenge form my dads place) 200+ hp here i come
