Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 12-06-2009, 07:51 AM
willl5031 willl5031 is offline
battery goes flat overnight
Hi there is there anyone that can help me?. I have a 1999 bmw 318se and the battery is going flat overnight and i cant find the problem. I have just fitted a new battery and checked all he lights and functions inside the car and they all seem to be working ok. I am very greatful to anyone who can help with this problem. Many thanks Will.
Old 12-06-2009, 12:04 PM
floresfrankie floresfrankie is offline
Re: battery goes flat overnight
I have this same problem...mine goes dead after a couple of days of not using it...I did notice that when I turned the car off i can still hear some noise behind the radio... I would think that there is a relay stuck that is not allowing a thing to turn off and causing it to drain...hope this helps!!!
Old 12-07-2009, 12:33 PM
I was begining to suspect the factory fitted cd autochanger and radio might be the problem then somone told me its the alternator so im no further forward but i will have a look around the radio and see what i come up with.
Old 12-07-2009, 04:41 PM
divot91 divot91 is offline
i have a 85 318i and it does the same thing, i think i was told it was a direct short in the alternator
Old 12-08-2009, 02:09 AM
Thanks very much for your help, i must admit you are not the first to tell me that but i wanted to find out from someone in the know. Thanks again i am away to get an alternator and fingers crossed its fixed.
Old 12-30-2009, 11:55 PM
daddyo8 daddyo8 is offline
More than likely, folks, what you're hearing after you turn off the ignition is the computer in shutdown mode. One thing I've noticed when mine was going flat was when I left the doors unlocked the computer would remain on for a long time and run down the battery and when the battery is low there are other electric gizmos that turn on emergency mode and overnite kill the battery.
Tell me if you have experienced anything like this.
Old 02-28-2010, 06:40 PM
i havent changed the alternator yet but has anyone had any luck with changeing it to fix the draining?
Old 08-17-2011, 01:38 PM
michaelpotte michaelpotte is offline
Before undertaking expensive or time consuming "try and see" repairs, check the interior light in the trunk - it has been known to stay on which will eventually drain a battery.
You don't have to climb inside and shut the lid, just open the trunk and put you hand on the lamp, if it is boiling, you just found the problem.
Old 02-05-2012, 04:50 AM
safwan051432's Avatar
safwan051432 safwan051432 is offline
if its possible, then please do a closed circuit current measurement, check if there are current leakage after the computer has shut down,
Old 10-11-2012, 08:29 PM
cac347 cac347 is offline
If the car has automatic air find the final stage resistor(blower motor resistor) and see if it is hot when the car is off. It's underneath the dash and on that year car I think it is on the drivers side. They are known for shorting and pulling current when the car is off.
Old 11-22-2012, 05:48 AM
magdelene magdelene is offline
I have a 94 318i. This happened to me once. I checked with my technician. According to him it’s a short in the alternator.
[spam link removed by moderator]
Old 01-02-2013, 06:43 AM
David666 David666 is offline
I have this same issue...mine goes deceased after a short time of not using it...I did observe that when I converted the car off i can still listen to some disturbance behind the stereo... I would think that there is a communicate trapped that is not enabling a factor to convert off and resulting in it to strain...hope this works.
limo service baltimore | baltimore limousine service | baltimore car service | baltimore limo | baltimore limousines | newport limousine
Old 02-22-2013, 07:23 AM
clifton50 clifton50 is offline
An assortment power, like the every-day type used in household equipment, is a set of electrochemical tissues that turn substance power into electrical power.
Old 02-22-2013, 07:44 AM
DeltaP DeltaP is offline
I did observe that when I converted the car off i can still listen to some disturbance behind the stereo... I would think that there is a communicate trapped that is not enabling a factor to convert off and resulting in it to strain...hope this works ! ! ! . . .
__________________________________________________ ___________________
Yeah, what he said.
