Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 12-05-2009, 09:30 PM
carrera0to60 carrera0to60 is offline
Timing Belt or Chain? 98 CE
I recently bought a 98 CE with about 80k miles for my commuter car. Overall I am very please with it but today I started hearing a metallic type chattering sound from the left side of the engine (looking from the front). Sounds to me like the timing chain is slightly loose and maybe the cause of the sound but when I search all the auto pats websites it doesnt show a timing chain tensioner. So do I have a belt or a chain? Does anyone have any other ideas what the sound is? it doesn't do it continuously but it does seem to only start when the engine is warmed up and at idle. I did a compression test and all the cylinders are in the ballpark so Im hoping thats means my valves arent taping..... I cant imagine it would have lasted this long if the valves were taping (driven it about 500miles so far). Thanks for the help in advance.
Old 12-05-2009, 09:40 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Timing Belt or Chain? 98 CE
You have a timing belt.
You can start by removing the serpentine belt and start the engine. If you don't hear the noise than its something with one of the accessories that the serpentine belt drives. Don't let the engine run to long without the serp belt on.
Old 12-06-2009, 09:48 PM
A belt huh? Well thats somewhat comforting, guessing that means its a non-interference engine then? The link in the FAQ's doesnt work. Ill take the serpentine off and see what happens.
Old 12-06-2009, 10:52 PM
roadrunner2 roadrunner2 is offline
You have a timing chain NOT a belt and yes, it is a non-interference engine.
Gates belts info.
It's unusual for a timing chain to wear out at only 80k miles. It IS possible to have a plastic gear lose a tooth, but that would throw the timing off and the engine would run rough and (apart from the noise) it's running fine, right?
Do what Airjer suggested and remove the belt and test.
Before you reroute the serpentine belt back on, check by hand (Engine off and key removed) each pulley by turning and applying side pressure at the same time.
Pay particular attention to the serpentine's tension pulley.
BTW, most timing belts also have a tension pulley.
The problem with doing nothing is not knowing when you're finished.
Old 12-07-2009, 10:43 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
If the engine has a timing chain (which it does), don't confuse the situation by giving advice pertaining to a timing belt.
That sound is probably the timing chain clattering against the tensioner because the tensioner spring has gotten loose. You may have to remove quite a bit to get the cover off but once in there, readjustment or replacement should be reasonably easy.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 12-07-2009, 11:21 AM
Gates belts info.
Yep it runs fine. Ill be sure to do the pulley check once I have the belt off. Replacing the chain tensioner seems like a pretty easy job, and cheap so Ill probably go for that anyway just to see.
Old 12-07-2009, 12:47 PM
Airjer_'s Avatar
Slip of the fingers, sorry. its a timing chain.
If it still make the noise with the belt off than I would be suspicious of a chain component making the noise as well.
Old 07-24-2012, 09:42 PM
gumby_ct gumby_ct is offline
I have a 1998 Corolla VE 63k/mi and a 1995 Geo Prizm 128k/mi do both have a timing chain? If not which one has the belt and what are the replacement intervals?
Also are Factory Service Manuals available any place other than ebay? Ebay & Paypal have put a bad taste in my mouth and I would prefer to avoid them if possible.
1998 Chevy Tracker 4dr, 4wd, auto,
1996 2dr Metro LSi, 3Cyl. 5spd, 107k mi.
My other car...in need of repair it won't start any longer
1995 2dr Tracker Conv. 4wd, 5spd, A/C 170k mi. (My Fav)
Old 07-25-2012, 07:46 AM
jdmccright's Avatar
The RustBuster
The Prizm has a belt....change interval according to the Gates website is 60k miles. Look in your Owner's Manual to verify this.
While many despise them, I find the Haynes manuals to be adequate for most simple to moderate repairs.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 07-25-2012, 02:06 PM
While I didn't see it before the timing belt is listed under Schedule I @60k/mi. So I assume it is a non-interference engine?
Looking thru the Owner's Manual I see the PO had timing belt replaced at 99,680 mi. so I should be good (I hope) for now, it's not quite 128k/mi yet.
Old 07-25-2012, 03:15 PM
jdmccright's Avatar
The RustBuster
Both engines offered (1.6L & 1.8L) for the Prizm for that year were non-interference engines.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 07-26-2012, 02:33 PM
That IS good news.
For the record this 95 Prizm LSi is a 1.8L 4spd auto cruises great on hiway but does have some noise and unstability in rear when you hit a bump in road I haven't been able to pinpoint.
Could it be a rear shock? Should I start another thread?
Old 07-29-2012, 09:22 PM
Joe W Joe W is offline
The sound from the rear over bumps could be bushings and/or the strut bearing plates. Hope this helps
Old 07-31-2012, 05:19 PM
Will this be hard to check?
I don't like that the car moves sideways when hitting bumps on the hiway.
Old 08-01-2012, 09:50 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Check the sway bar bushings. They are easy to replace and are often the problem.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
