Old 12-05-2009, 01:11 PM
mbecke2 mbecke2 is offline
1997 chyenne 350 heater/air problems
Ok first thing is my heater is not blowing as warm as it should. Im gettin 85-90 at the vent. The heater used to blow so hot (like 120)I didnt even have to turn it on, just turn the temp control on hot and it would warm up the entire cab. Now I cant even get warm in the cab. I recently did a coolant flush and have brand new coolant. Now here is the problem. The vent control (floor, front, defrost) switch doesnt seem to be workin correctly. Sometimes it seems like the air gets stuck and it doesnt come out the vents, and then if I hit a bump or rev up, Ill hear a thump like the flapper and then it starts blowing out the vent. But also Im not sure if the temp control switch is properly working. It does blow cold on cold and warm on hot, just not enough to satisfy me. The ac has never blown really cold for me either. Im wonderin if the flapper or temp blend door has something wrong. Just really frustrated. Heat used to work excellent and now works half ass. I checked the heater core and its fine. Both hoses are very hot. Did I do something wrong at the coolant flush?? Air bubble maybe? Or is it the actuator or temp blend door???? Thanks for the help.
Old 12-05-2009, 01:47 PM
jd-autotech jd-autotech is offline
Re: 1997 chyenne 350 heater/air problems
well take the rad cap off and let in run to purge the air out. and replace the thermostat there cheap and easy to replace. then check it again if not a service manual will help you diagnose it you can even check one out at the library
Old 12-05-2009, 06:33 PM
777stickman 777stickman is offline
What is the temp gauge reading? If it's reading low and/or fluctuating dramatically then you most likely have air in the system. Check the radiator every morning when cold and add coolant as needed. Keep the coolant reservoir full. It sometimes takes a while to purge all the air out.
The temp door actuator can be seen by removing the glove box. Small upside down house thing. Has index marks for full travel. Key needs to be on and rotate temp dial to watch travel.
Blend door actuator is at the left end of the plenum. Same house thing. Key needs to be on and the fan running to check travel.
Issues with both these door are usually caused by debris that has found its way into the plenum.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 12-07-2009, 12:56 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
If you can observe the selector door movement as you cycle it, watch how it moves. If it moves slowly before stopping it is likely an obstruction in the duct. If it moves then stops abruptly, it might be internal to the stepper motor.
Case in point for the latter.... When I got the Vibe, the fresh/recirc mode door would not move at all. Without going into gross detail about what I found in the ducting from my mother-in-law's neglect, the foreign mass had caused the motor to partially break one of the internal gear teeth and lay it against an adjacent tooth. As soon as the motor gear hit this, it stopped. I fixed it by removing the broken gear, turning it 180° and reinstalling it. The door only travels ~90° so it never turns the gear enough to hit the bad spot. Problem solved and no money spent.
Hope it's this simple for you too. good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
